TwinTurbo.NET: Nissan 300ZX forum - Pull the plugs and put a 27mm socket on the crank
Subject Pull the plugs and put a 27mm socket on the crank
Posted by Krazyd27(Houston) on August 21, 2013 at 11:40 AM
  This message has been viewed 238 times.
In Reply To Engine locked up? posted by SouthGaZ on August 21, 2013 at 11:05 AM
Message And rotate it by hand to check if its seized. Check inside the cylinders for fuel. If these are good then have your starter tested to make sure it's working properly.
